Telepresence
95' 4runner 3VZE Myriad of problems (SOLVED)
Before I start I have already searched the forums for the issues that are currently plauging my vehicle.
So lets start with the simple things first, I recently replaced the distributor, TPS, and the Oxygen sensor. Before I replaced the oxygen sensor the idle was up around 2000 - 2200 rpm. The new O2 sensor brought it down to 1200-1600 rpm. And the Old O2 sensor tested out bad when it was up to temp, So I know that fix worked good.
A few months ago I was trying to troubleshoot the rough idle of my 3VZE and noticed that the distributor was loose, the old cap's o-ring was dried out and had let some water in and rusted out the bearing. I replaced the entire distributor reset the ECU and retimed the engine. I really noticed the rough idle and it was very hard to set the base timing , I still cant set it to 15 degrees , it just keeps jumping around. There has always been throttle hesitation but the new distributor has made it even worse.
Now onto the TPS, The old unit tested out bad, which is what I thought was the problem with my trottle hesitation. Sometimes I press the gas and it took up to a full second for the engine to rev up or even react. I bought a new unit and installed it and calibrated it. but still the hesitant trottle persists and another thing to add occasionally it hunts for RPM between 1200 - 1600 RPM. and when in gear (5 speed manual) at low RPMs 900-1100 it gets jerky when I let off the throttle and let it idle down the road, and it starts hunting for RPM when in gear as well which makes it very hard and annoying to drive.
There are also some engine codes that I need to post but at the time of writing it is too late to go out to the garage and check the ECU for stored codes.
ANY help or speculation to what is causing these issues is very much appreciated, I'm tired of throwing parts at it and taking stabs in the dark. I'm at my whits end with this engine, I love the truck, but the engine had driven me bonkers and I plan to do a swap but for now I want to make it drive good.
