96-02 T4R Rear Axle and V6 3rd Member w/ 4.30 gears & Locker
tdorsloppy34
Complete axle but taken apart. Used the 3rd member while I re-geared my 4runner. Stock 4.30 gears with one chipped tooth (see pic). Stock diff with some type of EZ locker. No bearing whine at all, clicks around turns like every other drop in locker. No idea who set it up or how many miles are on it. Will separate from housing, $250 obo. Willing to ship 3rd member.
Housing has rust but in good shape. Passenger side seal leaks, axle shaft splines are good. 4Runner it came out of had 200K miles on it. asking $200 obo for housing and axles. Not willing to ship housing or axles.
Complete for $350, located in 92371. PM if interested.
excuse me, my 4runner is 97' without E-locker, if i install this gear without switch gear or my ECU is haveno setingfor it,how could i run the E-locker of this gear?
This axle doesn't have the factory Toyota e-locker, it has some type of aftermarket locker/limited slip that is not electronic. It would work just fine with your ECU. The only question would be if the gearing on this axle matches your front diff.
workingwheelswnc
