I have a 96 4Runner, 4cyl, 5 speed transmission. It started missing and sputtering anytime I would accelerate. If I held the pedal long enough it would straighten out and fly. But as soon as I let off or shifted gears it would sputter again. I had the catalitic converter replaced, replaced the plugs, wires and cap, the fuel filter and had the throttle body cleaned. It worked fine for a week or so and recently has started doing it again. The mechanic said I would need to replace the EGR valve next. I had the fuel pump replaced about a year ago. The weird part is, is that once in a while it will completly clear up and run fine for a day or so but at some random moment will start sputtering again. Is the EGR valve a viable replacement option at $150+? Please help!!
280k+ miles, regular maintenance and oil changes.
