97 4runner limited, how do you you remove the rear wheel flare.
rmoore
Hi All
I have a 1997 4runner limited. I have some surface rust developing around the rear passenger door that runs under the rear wheel flare at the top and the running board at the bottom. I am trying to figure out how to remove the rear flare without breaking it. I found the couple of screws around the inside of the flare. But I think it has the snap in retainers but have really tried to pull on the flare but it will not let go. I need to know i guess is if that is the proper method to remove, If I know you just have to keep working it until it pops loose I will but wanted to make sure that was the correct removal method before snapping the flare in half by doing it wrong. I went up on a couple of Toyota parts sites and found diagrams and parts list of the clips and retainers but it does not list how many I need assuming maybe I will break them to remove the flare. I tried to remove the interior panel but that did not look like a good way to go. Any advice is appreciated.
Ray
If you wiggle it front and back the trim piece will come off the plastic piece that is holding it on. If the makes sense. I then took a pair of pliers and just popped the pieces off, took some effort but they just popped out in the end.
Thanks for the reply
I will give it try and see if i can get the thing off. DId you wind up having to replace any clips?
Ray
In your avatar picture you don't have limited flares. I assume this is on a different 4Runner?
Yes those clips are a pain in the @ss.
