97 Limited 5VZFE OverHeating Issues
ridetime4
Added a thermostat to the truck once again to try and get the heater working for our trip to Nevada. Went ahead and installed a newer (Toyota brand) thermostat, after she overheated. Thought it was a faulty unit got another we tHought we found the problem.
A faulty unit but that waznt the case after two separate thermostat and without one she runs perfect but the second I go to add one I have the issue.
Any ideas? Really need to run the thermostat for winter time it's getting colder!
Sent from my SM-G550T1 using Tapatalk
When you say "overheated", did it actually boil over or just run warmer than you're used to? What is the actual temperature it reaches?
I just replaced my thermostat and am measuring about 190F, which is actually a bit cooler than I'd like. But since the thermostat seems to be rated at 82C, then 180-190F is about right.
Added a thermostat to the truck once again...
Do you mean a coolant thermostat or a heater control valve?
Cuz whether you have a thermostat in there or not you'll have heat if the heater control valve works correctly.
:cowboy:
I am sure it could be your radiator. How old is the radiator? If it is more than 10 years old, replace it.
DionicioLives
