97 limited wont idle
mehuddles13
I bought a 97 Limited about a month ago & haven't had any problems. It has 217k miles on it but ran great until tonight. I was almost to a friends house & when I slowed down to turn into his neighborhood it went dead. I put it in neutral & cranked it back, put it back in drive & it tried to die again until I gave it more gas then it ran fine. I let off the gas to turn the next corner & it died again. I drove around the neighborhood to see exactly when it did it or if it would quit but every time I let off it would die but as long as I was on the throttle it was fine & drove smooth. No check engine light or any other lights come on. Anybody have any ideas? I had already planned on putting new plugs & air filter in it hopefully tomorrow if I can make time because I have no idea when they were changed last but I'm not sure that is the problem since it runs smooth otherwise. Any help is greatly appreciated.
Update:
After hanging out for several hours I decided to try to make it home in the cold. When I cranked it the first time it immediately went dead. I cranked it the second time & drove the 15 miles home & it drove as good as it always has. Maybe the fuel filter got clogged? I'll drive it some more tomorrow & see how it acts.
try cleaning your throttle body,maybe the gum is choking the engine out when the truck is idling,I am a Honda tech and see this sometimes on Honda's with a lot of miles.You said you had no engine light correct?Good luck.
Thanks for the input. Any recommendations on what to use? Also just pull the intake hose & clean from there (in the plenum)? Correct, no engine lights. I put new plugs & a new fuel filter in today. I had no idea when they were last changed so I figured it wouldn't hurt. Plugs were nice & tan with a little bit of crud on them but not bad. I've never personally changed a fuel filter like the one on it so I'm not sure but when I got it off and blew thru ii before I threw it away it dang sure wasn't clean gas that came out of it. What little I got to drive it today it seemed fine. Thanks again for your help.
yeah, just take off the tube from the air cleaner and clean from there,open the flap with one finger and clean,don't spray too much directly into the throttle body,wet a shop rag and clean that way,be sure not to drop anything into the throttle body.They make a special throttle body spray,I work at a dealer so I'm not sure if autopart stores carry it.It may be a little hard to start afterwards just hold the gas pedal all the way down and crank.Let me know how its goes,good luck
Finally got time to clean it and it wasn't quite as cold last night....so far so good. Carquest actually had the cleaner for future reference. Thanks again for the help!
I know that it's a bit late, but you should also clean the Idle Air Control valve. It is located on the throttle body and has a plunger than can get carbon buildup on it and cause problems.
Glad your problem is fixed.I just learned today that my transfer case has to be replaced.Not to happy about that,although its still under warranty,thank god.:zoom:
