so how tough for a novice mechanic...lol i found a step by step instructions with pics even on how to change it.yotatech said:working in toyota dealerships over the years I see the people who get their t/belts done every 60k even before and i also see the people who take the wait and see aproach. At 60k the belt still looks brand new. At 90k the belt looks used and at 120k the belt is just starting to show glazing on the water pump side and
the threads are poling out at the edges. Most wait and see customers have tbelt failure in their driveway at startup, and if left up to the belt AVERAGE failure mileage is 130-140 k. To my knowledge the V8 tundra motor is the only interference motor toyota builds. It is not a horrible driveway/hand tool type job. Biggest two hurdles are breaking the crank bolt loose and compressing the tensioner to reinstall the belt.
Mr. Dabadina said:If I want the "norm" done on replacing timing belt, other belts, and water pump, what do need to order? I want to purchase parts my self and have someone replace it. A list would be great.
Thai said:Welcome to the forum. I have heard a lot of good things about the P5...good handling and a nice shape in my opinion.:rolling:
As for your questions, here is a link to answer both:
http://www.toy4x4.net/timing_belt/index.htm
Excellent write-up!! You will need a service manual and the special crank shaft pulley holding tool so you can remove the crank shaft pulley bolt and to retorque it.
While you're at it, consider replacing these:
1. Thermostat & Gasket
2. Cam Shaft Seals (X2)
3. Main Crank Seal
4. Radiator Hoses (upper/lower)
5. Accessory Belts - Alt, AC, Pwr Steering
6. Changing oil cooler hoses
Hope this helps.
