fastolds
hello all-
my 98 2.7 has a rough start most of the time when starting it cold. No CEL, only usually does it for 20 seconds or so. I pulled the plugs, saw that the #1 cylinder was wet compared to the other cylinders. I can't tell if its coolant, oil or fuel that is sitting on the piston when it happens. My coolant level is a little bit low, but i don't normally want to condemn anything without proof.
I swapped the #1 and #2 injectors, thinking that if it was one leaking down, the other cylinder would get wet too. It doesn't seem that way, it looks like #1 is still the wet cylinder.
I guess i'm looking at a head/headgasket issue, but i wanted to get some advice or thoughts before tearing into it.
The truck has 205k on it, and hasn't had any major repairs, other than a complete exhaust system through the years. I changed the oil every 3-4k, and the coolant itself still looks green and doesn't have a crappy burnt smell.
One thought i had other than HG is that carbon buildup in the cylinder is absorbing fuel for cold start, I'm in the process of running top engine cleaner through the engine, and we'll see if that helps.
Any thoughts?
thanks
Adam
Any thoughts?
thanks
Adam
