42rnnr
This problem went downhill in one day. It started out as if the battery was not charging. The starter was not turning as fast as it normally did but it would start. It got worse, although a couple of times it seemed normal, but finally died altogether after 10 or 20 starts. I checked the battery, it's clean as a whistle, everything seems tight as can be and the battery is fully charged, lights, etc. all work. Finally tonight after reading some posts I decided to shut off my alarm system and gave it a try (knowing the battery is charged). Now it's only rapid clicking noises. I am going to jump start it in the morning, but I'm guessing that won't help and I either have a bad connection or starter contacts going out. I would say help, but I think I've read enough posts to solve the problem but I thought I would post anyway and update my condition as I can and hopefully give somebody else with the same symptoms a diagnosis. I'm not real thrilled about the possibility of taking the starter apart. I will exhaust all other options first, like cleaning the contacts and checking the ignition system with a volt meter/light gauge. Wish me luck!
