99 4 runner limited
mrsteel
Please help!! This vehicle runs great for about 30 minutes then sputters and dies. All new parts in last 6 months, and all OEM fuel pump, fuel filter,MAF, IAC, plugs wires, coolant temp sensor, cleaned throttle body, new cat, new 02 sensors. no codes or check engine light
Sounds like one possibility could be something getting heat soaked and failing. I would think it would cause some kind of code but depending on what it is, maybe not. I would try hooking up a obd2 reader and letting it record while it sputters out to see if it gives you any indication as to whats happening.
Sounds like a tricky one! Good luck
seltzernator
