Passing My 02's Final Emissions Test - An Odyssey
MikeMH
Member
TLDR: Over the past 4 months I've battled a variety of CELs in order to pass my final emissions test here in GA (>25 years are exempt). In the end, it was a combination of my charcoal canister and Cataclean that got me to a spot where I could pass.
More detailed:
Like many, I've fought intermittent P0420 and P0440 codes occasionally, and the past few years have had pretty bad timing where I get them when my renewal and emissions are coming due.
I was primarily getting P0440 codes, as well as a fuel smell after turning off the car. Research here lead me to the rollover check valve, so in April I dropped the fuel tank and replaced the valve, as well as the fuel pump and some other misc. seals. I was actually code free for short while, but then started tripping P0420.
P0420 I could clear and it would stay away for awhile, but it would return and started returning pretty immediately. Then I started getting P0440 again as well.
I started with replacing the downstream O2 sensor, which didn't solve it. I bought a smoke machine and checked the exhaust and intake repeatedly. I found a couple minor leaks on the intake pipe which I addressed with some sealant. No more leaks. All the while I was monitoring OBD2 data and uploading to ChatGPT for troubleshooting assistance, which...sort of helped.
I changed spark plugs, air filter, cleaned MAF, replaced gas cap, greased my gas cap with some bearing grease to create a better seal. Was still getting P0420 and P0440 codes. I was really hoping to avoid changing the cat due to the $$ and I only needed to get through one more test.
During this time, I was still getting CELs, so I failed an emissions test and got a 30 day extension on my renewal. The clock was ticking.
At this point I had reached the limit of my troubleshooting abilities so I took the truck to a local Toyota shop. They recommended replacing the cat and the charcoal canister. Not really wanting to drop $2500 on this I decided to try a few other hail mary's first.
I picked up a bottle of Cataclean based on other folks having success...after all, I just needed to pass one test. I also got an OEM charcoal canister as I had already been mentally preparing to do that work after doing my rollover valve.
To my surprise, the Cataclean actually got me able to reset my codes, and pass the "readiness" drive cycle for the catalyst for a short while. It then popped a CEL again before I could fix my P0440.
I changed the charcoal canister, got another bottle of Cataclean, and was able to get all monitors "ready" and pass my last emissions test this morning!
I still have, according to ChatGPT, unusually high LTFT at ~19% on average cruising on the highway. But the truck drives totally fine, so I don't think I'm worried about it. Glad to have it behind me!
As usual, thanks to everyone on here who posts their own projects and helps people like me solve their own problems.
thadjay
