birchy said:
What's the difference? Are the Tundra ones more heavy duty or?
try doing a search either here or on yotatech.com. Plenty of informtion on this upgrade.
As to your truck pulsating when braking...like others have said, the problem is more than likely caused by the rotors. My 4Runner developed the same sensation you are describing when braking about 2wks ago. It felt like pushing a grocery buggy with one wobbly wheel. Other than braking, my 4Runner drove fine.
As for my issue, I knew it could not be my brakes b/c I just upgraded to the tundras, so I took my 4Runner down to a local tire shop and had them look at it. They confirmed my brakes were fine, and confirmed the problem to be caused by my left rear tire. The tech said it's the same feeling he feels when a tire is on the verge of seperating. He spun the tire on the machine and you could see the wobble in it. So he swapped my spare on and the now my 4Runner drives fine. It sucks b/c I bought these tires new and they have only 14K miles on them as we speak. I have already odered a new tire and will return the defective tire this weekend.
I just thought I'd tell you all this to say, it is not always bad rotors that can cause your truck to pulsate when stopping. As I have just learned, sometimes a bad tire can cause it too.
If you want to know for sure if it's your rotors or not that need replacing, take it to a tire or brake shop and have them confirm it with you. Could save you some money from having to replace parts that are not needed. And to think, I was only one click away from ordering new rotors myself...
Oh and if in fact you need new rotors, just replace them yourself. They are extremely easy. Just unbolt the caliper and they come right off. Swap the new ones in and just rebolt the caliper on.
