99 LTD: Shudder on accelleration at speed
watersna
99 LTD, Auto transmission, 4WD.
Lately I've noticed a kind of shudder, like repeated lurching, when accelerating under certain conditions:
Driving at highway speed (~65)
Slow down below ~50
Accelerate from ~50 to 65+
As I re-accelerate, I feel lurching around 55MPH then it settles down up past 60.
If I'm accelerating from a stop or from lower speed without decelerating first, it doesn't seem to happen.
Checked codes, showing nothing.
I also checked ATF. Level is fine and it is slightly brown but transparent
FWIW I just swapped springs and shocks to bilstein/OME with a 2" lift. Doesn't seem to me like that would have anything to do with it but figured I'd mention it.
Anyone have suggestions on what to look at next?
Slow down below ~50
Take a look at your plugs if they are good. Could be dirty maf. If the maf is clean then a fuel issue, may be dirty injectors not keeping up.
Slow down below ~50
Does it happen in a certain rpm range? Do the rpm's jump with the lurching?
Cleaned the MAF sensor, replaced Air filter and spark plugs/wires today and haven't been able to replicate the issue so far, so it's looking like one of those was the fix. I'll take it out for some more in-depth testing tomorrow.
Thank you!
Runvod
