A couple more suspension questions...
Cubslover
Then I'll be done, I promise.
'03 SR5 V8 4X4
I will just be doing some trail running and mudding.
I have 2 lifts in mind....
1.) The Standard OME 3" with medium front coils and light rear coils.
Question 1: Would you take the Toytec "Superflex" Coils over the OME for the rear?
2.) a peicemeal setup (will be similar to the Toytec Ultimate lift)
Bilstein 5100s front and rear with 3" Lift coils of undecided manufacturer.
Question 2: will these work with most aftermarket lift springs? Such as OME, Toytec, Icon, Eibach, etc?
the super flex coils give 10% better load cap. than stock but similar ride quality, the OME will be a bit firmer without additional rear end weight. do u want to go a full 3 in. front & rear? or more like a 3/2 lift? any of those coils will work with the 5100s, maybe FJs springs will keep $ down a little, the full OME setup (springs & shocks) work well together, but will lack front end adjustability, its kinda more or less what shocks for the kind of ride feel u want/need, personally, i like to keep things matched as much as possible so they work well together. id say, either get the whole OME , or for a closer to stock ride, get the 5100s with FJ springs & rear spacer, the 5100 with ome coils will work also, but may give a slightly firmer ride depending on which ones u get.
