a day at work on my 4runner
FCSCouto
i suppose it was a pretty good day of work, one blub was out behind my climate control, so i took apart everything for that and decided i might as well replace both so i did, and its beaming brightly now, i "fixed" my check engine light...it came on a while ago took it to the dealer and they replaced the o2 sensor (about 5 days ago) but the light came back on 3 days ago but i dont have time to go back yet, so i just disconnected the battery and connected it and so far so good...only one problem left, that for the life of me I cant figure out.... my tailgate window.. it goes down fine, but "pulsates" when it goes up. i took it all apart and greased everything i could, but the problem still isint fixed, the motor must be fine because it goes down normaly..i think i have something messed up wire wise because when my top or 3rd break light pulsates the same way the window does as its going up. any idea?
Well the CEL will most likley come back on, Have it checked the ECU is trying to tell you something the codes are sometimes multiple things that could be wrong so the O2 SENSOR MAY NOT HAVE BEEN WHERE THE PROBLEM WAS.
The rear window regulator labors more putting the window up then down. could be that.
well if he disconnected the battery, he cleared the ecu's memory and its no longer stored.
if/when the light comes back on, get the code pulled asap
delislerebecca
