A few mods..suggestions required
lildevil23
Stock audio system in my V6 'O4 SE is pathetic, my 92 camry stock sounds better! :upset:
I have the regular (non JBL) system and need suggestions on what to get WITHOUT disposing of a few features(double deck cargo system& rear parking mirrors) Dont mind spending a lil as long as the functionality of the two featuers is not compromised.:help:
Also any input on adding a nav system along with a backup camera would be welcome, that way I can get rid of the rear mirrors allowing me some leverage with the speakers(if need be).
Click the search button. There have been many posts about upgrading the stereo system, speakers, amplifiers, adding aftermarket DVD, navigation system, installing OEM navigation, and even CarPCs.
Re: Thanks..
lildevil23 said:
Did that..thought would get some customized info..thanks for the directions though:)
Customized info is no problem ... but you gotta ask a customized question first.:cool:
Keeping the double decker is your biggest challange. If you are open to using the lower portion of the cargo area you might be able to fit a 10" sub in a long wide but short box. Your other option would be to custom make a fiberglass box within your storage area in the back right panel. There is lots of room in that back panel if you take out the storage compartment, but just keep in mind the heat that will be in that area.
If you are not looking for a lot of bass then adding an amp and spending some good money on some speakers for the doors would be another choice.
