My new 2011 Trail will be arriving May 13. I have decided to replace the stock tires with Bridgestone Dueler A/T Revo 2 LT Load E 265/70R17 because I will be doing some off roading.
I am going to order 5 tires so I have a spare. I would like to do a 5 tire rotation but I will need to order a new wheel because from what I have read the spare does not use the same wheel. Is that correct? I called Toyota and a wheel will cost $470.09. Wow. Is there anywhere else to order the stock Trail wheel. I know forum members sometimes sell their wheels but usually 4 at a time.
When I get the new LT tires they will need more air pressure than the stock tires. I figured it out to be 45-46psi. I have never had a TPMS in a car. Can this be readjusted for the new tires or do I just forget about using the TPMS. Will it sound an alarm for pressure too high?
I have been looking at deflators and inflators and think I might get these.
Amazon.com: ARB E-Z Tire Deflator: Automotive
Amazon.com: VIAIR 400P-Automatic Function Portable Compressor: Automotive
I have read some recommendations on how much to air down on dirt, sand or rocks but I know every tire is different and the type of vehicle must matter too. How about for my LT Load E tires. They have a stiffer sidewall and some recommend because of that you should air down to even lower levels. What psi should I use for plain dirt roads (washboard) and what is the max speed at that setting. Sometimes roads change from poor to better and I want to be sure if I air down to say 20psi I don’t drive too fast when the road is better.
Thanks for any help, Kent
