A small oil leak...?
Hi all, I have a 2006 4Runner SR5 that I have had since brand new, has 140,100 miles on it now. At about 95,000 miles, when having oil change at dealership, they indicated that the truck had serious oil issue/leak, and would need over $2000 to fix. I said no thanks, finished oil change, and took to local mechanic (who is a diesel mechanic during day job and National Guard for 20 years) to check out. He washed it up, degreased it, tightened a few bolts and the filter, and said nothing needed to be replaced.
About three weeks ago, I took the truck into a quick change place for an oil change (about 139,000 miles), and they told me it had a small leak and should replace the oil gasket at some point, and should watch it.
This week, I have been noticing fresh oil leaks (about the size of a mini-donut) on the garage (and honestly, there have been... have a 2002 Avalon as well), but when I check it, the level is fine.
Should I be concerned about it, or take it to my friend/mechanic? This truck has been a beast, absolutely minimal maintenance, but want to make sure to keep it going well for another 100,000...
Take it to your friend if that is an option. Better to catch it before it becomes a bigger issue. It could be a simple fix since you've caught it early.
Your friend probably took care of the leak at the time by tightening some bolts. But, at times, on the oil pans, it can create leaks also.
Take it back to your friend and if it's the pan leaking, get another gasket and change the oil at that time. Should be an easy fix.
make sure its not transmission oil- a lot of people here including myself had rusted out transmission cooler and power steering lines
