A-Trac and VSC
adoihcj
Can someone do a better job of explaining these systems to me. The manual is not helpful at all (at least to me). When should I turn off/on these systems? Keep in mind that I have the SR5 with part-time 4WD.
A-Trac is used in really dicey situations, or when you're stuck or likey to be stuck. It works by sending power to the wheel with the least slip while at the same time braking the wheel(s) with the most slip. Only works in 4Lo in part time 4WD SR5.
VSC is Vehicle Stability Control. It works in a similar sort of way - but it stays on all the time unless you shut if off. It basically saves your butt when the truck starts to slide sideways, in either an oversteer or understeer situation by braking certain wheels, depending on direction and yaw rates etc, to keep the truck going straight.
If you want to burn doughnuts in the snow, shut VSC off. It can be shut off by holding the traction control button (not A-Trac) for a few seconds. You will see the slippery car tracks icon light up to tell you it is off.
So, A-TRAC is for slogging through the tough stuff, VSC is to keep you from ending up in the tough stuff.
Hope that helps.
Hope that helps.
Very helpful, thanks for clarifying!
There's many posts in 4th gen, some in 3rd gen and great writings in the FAQ's. There's very minor, subtle differences with the 5th gens ATRAC and VSC but overall it's very similar.
Dekeman gave a nice, concise quick summary.
:cheers:
Hope that helps.
Very well said!!. It has come on at just the right times to compensate for my driving errors (lack of patience) on snowy roads. I am very impressed with the VSC system.
