I'm confused help me out. I thought that A-Trac was turned off automatically in 4lo so that the wheels could spin and pushing the button simply turns it back on. A-Trac (to me) means active traction control which I thought was alsways on unless you put it in 4lo. You can turn it off in 4hi by stopping and holding the trac. button for 3 seconds. Am I missing something, or what is the difference between A-Trac and traction control.
The OM could be a little clearer on these things, so I like to test them out for real
TRAC is essentially traction control, in 2wd if you spin your rears the system will kick in and cut your throttle so your tires do not spin and you can hopefully move. Again the same with 4H & TRAC, will cut the trottle so you stop spinning and hopefully can move. TRAC is always active, unless you push the little button (car with little s tire tracks behind it), if the off move you can slam the gas and spin to your hearts desire. A-TRAC is active traction control, and can only be engaged in 4L. A-TRAC will physically apply the brakes to certain wheels but will not cut the throttle, giving the ones with more traction more power. I cut this (below) from the FJ forum:
"Trac : Traction control. All FJ's have this, both 2WD & 4WD. Works automatically when ignition is started (no push button needed). Works by applying brakes and controls (decreases) engine throttle to give added traction to varying wheels when system detects wheel slippage/spinning ("think spinning your wheels on ice"). Works all the time in 2WD and in 2H & 4H. This system basically helps to maintain traction in slippery conditions such as wet/icy for forward movement by applying brakes and controlling engine throttle to regain/maintain traction as a safety feature.
TRAC is disabled in 4LO. Again, you don't want this system to control engine power when you are climbing obstacles.
ATRAC : More aggressive form of TRAC & for 4WD OFF ROAD use only. Does the same thing as TRAC except it doesn't cut/control engine throttle. Instead, it transfers torque from slipping/spinning wheel(s) to non slipping wheel. This gives added traction & forward momentum to overcome Off-road obstacles. This can only be engaged while in 4LO and by pressing the "ATRAC" switch."
Go play with your systems, that is the best way to learn how they work
