So I guess my question is, do I need a pre 00 trans or an 00-02 trans?
I would suggest using a 00 or older with the cable. I only suggest that due to the 01-02 models are using the ECM to control the line pressure servo. Unless that is built in to the trans controller that you are wanting to use(from the title of your other thread), then the older trans would be the easier to adapt to what ever you are doing. Less electronics to deal with.
