a340h to w56
richiegrich
hey all, i came up on a cheap w56 and am planning on swapping it in soon. aside from the clutch assembly is there anything else i need to replace? specifically can i use the same ecu and front and rear drive shafts? any help is appreciated.
ECU can stay the same. You just need to trick the neutral safety switch harness from the auto trans into thinking you're in Neutral or Park. Basically you solder two wires together and heat shrink them, and you're done.
Rear drive shaft for the manual is a tiny bit longer (3/4"?). In theory, the shorter one can expand to take up the slack, but I've heard mixed things about using the auto shaft with the manual, so I bought a longer manual shaft for the swap I'm going to do.
I hear the front shaft is the same.
You need to swap the flywheel and flywheel bolts too. Bolts are different lengths.
I hear the trans crossmembers are the same, but the crossmember-to-trans MOUNTS are different. I bought a manual mount to bolt to my crossmember.
You also need the clutch line. Either the original type hard line and soft line combination that runs to the trans, or an aftermarket type. Original type is hard to find without a donor truck. I bought a stainless braided aftermarket, which means I'll have to do some hacky mounting on the firewall with some screw-in brackets.
There's some other trickery involved to get your reverse lights going again, to plug in the clutch start and cancel switches if you want them to work correctly too.
thanks for the info! i already bypassed the neutral safety switch so one less thing to worry about. good luck on the swap!
Do you have the 3vze or 22re? If memory serves me the a340h is behind the 3vze and if so I'm pretty sure you will need a R series transmission due to the bell housing. I used an r150 series behind my 3.0 when I did my swap. As for the drive lines I reused my front one with no problems, I then got two 3/4" driveline spacers from low range off-road. I have not had any issues with the spacers so far an I've put them through their paces. I got them on sale so it was cheaper than a junkyard driveline, I also just replaced u joints and didn't want to do that again for a while
i got a 22re in mine. pretty sure its a a340 but could be wrong. thanks for the info on the spacers. i'll look into how much those run as i'm sure this process is gonna add up.
mek
