I'm due for new tires and was thinking of going from 265/65-17 to 265/70-17. I have an '04 2wd Sport V6. The tires i'll be getting are Nitto Terra Grapplers. Will I have any issues with clearance/rubbing? Would you recommend this upsize, or should I just play it safe and go with oem size?
I used the tire size calculator from the sticky above and it warned that you should not do more than 3% change in tire size from stock. This would be a 3.3% change. What's the warning for?
Thanks!
Thanks!
