ABS Codes After Wheel Bearing Replacement
My front brake lines were cracked all to hell. I had the turning right at a slow speed and braking which would activate the ABS. Since I replaced the front brake hoses with new that issue went away.
Do you have rust chips on any of your ABS sensors? That will fake a wheel speed difference that causes the ABS to activate.
Found the issue... forgot to run in the bolt for the front left speed sensor at some point and it had wiggled out a good bit :doh: Tightened them both down and made sure they were fully seated, drove the 30 minutes home no problem and now everything is back to normal
Funny enough this probably benefitted me some as there was definitely some air in the ABS that got pushed out. I've had a shitty pedal feel for some time that's much better now :thumb:
So far resetting the ABS codes seemed to work, but oddly enough I had to keep the shorting bar in for it to clear? Everywhere I read said to take the bar out which worked fine for me pulling codes, but for whatever reason it wouldn't let me clear them until it was back in place. At any rate I went for a short drive and the lights stayed off, we'll see how it goes! :)
[MENTION=115088]theriddler[/MENTION] I would perhaps try this; jump the ports of the ABS diagnostic and hit the brakes 8+ times in 5 seconds, and maybe play around with the shorting bar if it doesn't work the first time
Thank you I'll try that!
AndiGarage
