ABS Codes
chadsy
ABS Woes
When I bought my 4runner about 2 months ago, I noticed my ABS would act up. It would pulsate when coming to normal stops and go absolutely crazy when driving on gravel. I had since just deactivated it. During this time it never gave a ABS light until I unplugged it from the actuator.
I replaced my front breaks this weekend and decided to look further into this issue. I researched and researched and decided to pull each sensor and give it a good cleaning. I found a lot of oil on the two rear sensors and tried to clean out there tubes (for lack of better description) as best I could. I plugged the ABS module back in and turned the ignition and to my surprise now found that the ABS light was glowing.
I did some more research and found how to pull the ABS codes and this is what I got:
33 - MALFUNCTION AT RIGHT REAR SPEED SENSOR SIGNAL.
34 - MALFUNCTION AT LEFT REAR SPEED SENSOR SIGNAL.
21 - OPEN OR SHORT IN 3-WAY SOLENOID FOR RIGHT FRONT WHEEL OR DEFECTIVE ABS ACTUATOR.
22 - OPEN OR SHORT IN 3-WAY SOLENOID FOR LEFT FRONT WHEEL OR DEFECTIVE ABS ACTIATOR.
23 - OPEN OR SHORT IN 3-WAY SOLENOID FOR RIGHT REAR WHEEL OR DEFECTIVE ABS ACTUATOR.
How is this even possible? Could it be that I didn't tighten them up enough or could it be there is something major wrong with the unit itself? Why wasnt the light on in the first place?
How did you deactivate it? I don't know a way to turn off ABS without setting the light off. It should have been on the whole time.
Sorry , I should have been more clear.
Before I pulled the plug from the actuator, the light was never on. When I did remove the plug it did come on. When I plugged it back in after cleaning the sensors it remained on.
Mike Sargent
