benztech82
Member
Hey all,
I got a weird brake issue. When I press the brake pedal it feels fine for a second and then it's slowly going all the way to the floor.
No codes, tried bleeding brakes with scan tool as usual, rear with scan tool and front conventional with buddy assist. My truck is 08-2004 which is a part number change for ABS unit. I suspect that I have to replace the whole unit but not too sure and don't know if newer unit will fit from 2006+ since mine could be with older unit from 2003 up to 2005. Did anyone have this exact issue or knows if older 4th gen can have 2008 ABS assembly?
Thank you!
Thank you!
