I'm not sure why that would be happening, but I am interested in the lights. Can you tell a big difference in the brightness of the lights? Actaully that gives me an idea. You might want to try putting the stock bulbs back ina nd see if the ABS light goes off. Just a thought.
there is no INCREASE in light per say but at least now they come ON in a millisec and turn of the same way. plus they run MUCH cooler and will never turn WHITE/yellow. And they are clear in day time. Look better, last longer.
I'll upload pics later tonight....
....thinking about doing the same to the turn signals. no need for filament to heat up and down.
they seriously need to start making the correct size for the 4runners so i don't have to waste an hour each bulb to install.
Took some pics tonight.
You can see some red in here above the brake light. That's the turn signal bulb with a red silicon bulb cover. They suck. I'm going to replace it with an led bulb. hmmm...amber or red?
They don't look like this. The camera just took in too much glare.
More accurate.
I forgot what size i got, but they were the only ones Wally World carried. (Wal-Mart)
The glare spreads the red out too far. They are 2 pretty circles. Very different from normal tail lights. Me likes being different.
Cheers
Davi
ps I will take daylight shots tomorrow and post them.
Here is another site, but their bulbs are NOT as bright as those linked above: http://www.superbrightleds.com/1157.htm
The photo below is their load equalizer.
More often than not, those "load equalizers" are simply a large resistor. I bought a bag of some similar to the photo above (gold anodized aluminum case) from Digikey.com to use on my motorcycle. They were about $5 each.
I bought 10 ohm resisters capable of 25 watts. At 12 volts, this means 12 x 1.2 amps = 14.4 watts. I found this more than enough of a load to make things work. 1.2 amps comes from 12 volts / 10 ohms.
Note they are connected in parallel.
They do get a little warm (hence the aluminum heat sink), so I would mount them so that they aren't against anything plastic.
