AC is pouring water in the car as we drive.
T4RT
Hey guys. I am currently on a road trip to Missouri and my AC is pouring water into the car. Do I have a clogged drain pipe or do I have a bigger problem here? I was 12 hours into my drive before my problem started. I will have my wife monitor your responses as we continue. Thanks for your help in advance. Here is to keeping our feet dry until we get to our destination.
Sent from my Pixel XL using Tapatalk
97.66532% sure the driver side has a port to inject evaporator cleaner into and the evap drain is on the passenger side.
Do you have an endoscope attachment for your cellphone to look inside the drain? If the water problem comes after 12hrs of use it possible the hvac iced over, blocking the drain. On my work truck I activate the heater on high for a few minutes to jump start the water drain. The work truck tends to create some ice.
Have you had the oil changed recently?
The A/C lines drip down while the mechanics do the oil change. Sometimes they "Pinch" the hose so that it doesn't drip on them. This will cause the condensation to back up into the Evan box and spill over into the floorboard.
Just a guess hope it works.
albertpeter156
