Would the stock AC power outlet on my 08 Urban runner put out enough power to run my sump pump in my basement? Also, would I have to hold the throttle slightly over idle to get rated output from it?
I can't pull the pump out of the hole the way it is plumbed but, going by measurements and appearance it looks like a 1/3 horse pump that would pull 11amps/900watts with a 25' power cord (4runner to pump). So, it isn't that much power needed but, I wonder if the 4runner at idle would be enough?
You are right, I really need to know the exact pump I have because the more I look at 1/3 hp pumps the numbers are all over. I found some that only pull 5 amps on a 10 foot cord at 115vac. I'll do some more research.
Sorry I am late to this one but no way will your truck run a sump pump, not only for power requirements but your outlet in the truck doesn't have the ground lead like a sump pump plug usually has.
If you are worried about your sump pump going out there are some really slick dual pumps that run off a battery. Here is some info on them:
