accessory belts
4runna08
Im trying to find a diy to replace the belts, i tried searching here and yota tech with no luck.
vehicle is a v6 4runner
can someone post a link?
THanks guys!
what belts are you looking to replace? Accesory belt as in alternator and A/C or you talking about Timing belt?
OK I dont have a link to those, however is pretty straight forward. I will see if my Hanes manual at home gives good instructions then I can scan and send to you. Otherwise each of the three belts can be removed by loosening the pivot and tension bolts. The altenator has a tension bracket underneath, as well as the power steering pump. I did not crawl under truck but I am assuming the same of the A/C belt. Sometimes you can squeeze the belts over the fan but I am not sure on the 4 runner.
