Acura TL cabin filter?
Hank
I know this doesn't relate to 4Runners at all, but does anyone else on the forum own a current gen Acura TL? If so, my question is whether the cabin filter is a user serviceable item. The maintenance log book doesn't mention anything at all about a cabin filter. I'm pretty sure that the TL has one though.
I have checked behind the glovebox in my sister's '06 TL, but couldn't find any compartment that can be opened. I've even removed the lower panel under the dash/glovebox on the passenger side, but only found a gauze-like padding glued to the removable panel. With the panel removed, I can see what looks like the motor assembly portion of the blower fan. Any advice or knowledge would be much appreciated!
If the current gen is anything like the previous gen TL/CL, there is a "knock-out" type panel. The the panel either needs to be cut out with a utility knife or popped out. I don't remember, my buddy had a 2003 TL-S. Once it's out, the filter kit comes with or behind the cover is set of screws to replace/reattach the cover. It doesn't have an access door/tray like the 4Runner does.
