zsmithku
I had asked this question in a previous post, but thought I would try to gain more insight about this before I change my current setup. I am making a 1200 mile trip next week while I pull a U-haul trailer. Because of this, and remarks from other members, I purchased a Hayden add-on trans cooler rated for 2500 lbs of towing. It's dimensions are about 7 inches by 11 inches. From the instructions it said the best way to use it was to go through the stock radiator then into the add-on trans cooler which would then flow to the transmission. That makes sense since you would be getting colder fluid by having it cooled twice. However, several members said that I should bypass the stock radiator and just use the add-on trans cooler. But this doesn't seem to make sense. I can't imagine the fluid getting cooler by going through a smaller piece of equipment. Physics would say that going through both the radiator and then the trans cooler would be the most effective. Before I put all my trust in this 7x11 piece of air cooling metal I want to get all my facts straight.
Thanks again.
Thanks again.
