Addicted Offroad's new BOLT ON winch bumper! 96-02 4runners!
AddictedOffroad
We just received the new crossmember prototype in over the weekend.
These new crossmembers will bolt on to your current 96-02 4runner. All you need to do is trim off the front flat original mounting piece on the front of the frame. This can be done with an angle grinder, sawzall, or die grinder easily. No welding is required at all!
All hardware will be included with the bumper when shipped.
Shipping is a flat rate of $99 to the continental US. Please call for Canada shipping quote. These will be ready to go in the next couple weeks. So, get your order in NOW if you want one at $50 off.
Scotty that looks just like the one I got in April except for the tabs with the two bolts on the end of the mounting bracket. What are the tabs for? Do they just add extra strength to the bracket? Are they mostly for people who are running a winch? Just wondering if I need to order another bracket. I don't have a winch yet and probably won't for quite a while.
Yours is welded on. You're fine. No need for anything else.
This was simply a needed mod so that not everyone needs to weld it. Not everyone has the ability to have it welded. This solves that issue.
Damn Scotty nice work. You make me want to s-can my ARB bumper. :gun4:
I may have missed it, but what does the total set up weigh?
josh
Good, been doing a lot of work replacing stuff as I break it.:jump:
Need to fix an issue with the 4wd, but after that I'm heading in the meth injection direction.
josh
Well, let me know if you want to get a better approach angle up front. :hungry:
And, we should have our rear bumper released soon as well.
Is there no way to make the cross member compatible with a oem bumper?
I have always wanted a winch to work with the oem bumper.
peacefulpiranha
