Adding 1" lift to FJ TRP Pro Bilstein coilovers
Wandering1
Hey all,
Need some assistance on this one so thought I'd come to the experts.
I have a TRD Pro Bilstein front/rear setup that I'd like to get another inch out of.
Would this Toytec spacer work? I believe I've seen people say they ran it on the coilovers, but the Toytect item number has changed so I wasn't able to confirm off old messages. I also reached out to Toytec, but thought someone here might already know.
I got these springs so add the extra lift in the rear: Dobinsons Rear Coil Springs for Toyota 4Runner and FJ Cruiser(C59-599) – Dobinsons Direct
Anyone see any problems or recommendations with this setup? I did get some small spacers for the KDSS lean.
Another question involves the mounting of the reservoirs with KDSS, I saw some discussions around some modifications that needed to be done to mount the resi's on KDSS vehicles. These referenced pictures that are no longer available, so I was hoping someone could let me know what, if anything, needed to be done there. It didn't seem complicated, I just can't see the images anymore.
Thanks for your help in advance, really appreciate it.
Hey all,
If you have the FJ cruiser version, then you already have a 14" springs. You'll need a taller spring to avoid adding preload. If you have the 4runner specific version which utilizes a 13" spring, then getting a standard 14" spring will give you a legitimate lift.
I won't run the toytec spacer but it should work for your application.
I do have the FJ Cruiser version. That's what went wrong when I ordered the Dobinson coil for the front coilover before I knew about the spring length, I believe that is just another 14" spring so it wouldn't provide the lift.
When you say you won't run the Toytec spacer, what does that mean? Is there a specific reason you wouldn't run it?
I want to make sure I'm putting on a decent setup and not something that's going to cause issues in the future.
I previously had the ToyTec spacer on the 4Runner TRD Pro Bilsteins, and had no problems with it. It's really only a half inch spacer (1inch total, but only half inch thicker than the stock spring seat that you replace giving ~1inch lift at the wheels) I would've left it, but had the opportunity to swap with the FJ TTUE taller springs. Like perf0mance mentioned, the ToyTec spacer should work on the TRD FJ shocks, too. I still have the spacers if you're interested. Let me know
