Adding a factory sub enclosure to a non-JBL equipped 4Runner
Catfish
Member
Yep. I have an '07 SR5 with the regular (non-JBL) system and finally got sick of the weak sound. A while back, I replaced the headunit with a Scion T1809, replaced all the door speakers with Pioneer 6.5" 3-ways and replaced the front door tweeters with Clarion 2" full-range speakers. It sounded better, but not great.
And so, I bought a factory sub enclosure with an aftermarket JL Audio (8W3v2) sub from a forum member here. I also bought an Alpine MRP-M200 mono amp to push it.
The factory sub enclosure fits perfectly in the cargo area, with a little bit of modification to the quarter panel trim piece. And so....
I used the following link to dismantle the interior and get to the sub/storage area itself. How to Remove the Navigation ECU from a 2003 Toyota 4Runner
I then followed Ark Swamp Rider's instructions for installing the sub and amp, running wires and such.
http://www.toyota-4runner.org/4th-gen-t4rs/62400-replaced-jbl-sub-added-amp-install-pics-info.html
The instructions on both of those links were very clear and easy to follow. After that, I was flying blind.
IMG014.jpg~original
The storage area...just remove the two bolts holding it in place...
IMG015.jpg~original
...and drop the factory sub enclosure in. It fits perfectly!
IMG020.jpg~original
Run all the wires and hook it all up. My amp lives under the passenger seat.
Now then, it seems that some cutting on the quarter panel trim piece is required to make it all fit. The alternative to cutting the trim panel is to buy a new or salvaged one. The dealership quoted me $500. No thanks.
IMG019c.jpg~original
Here's the trim panel...the area outlined in red is the part that must be removed in order for the panel to fit in place.
IMG017c.jpg~original
And here it is from the back side.
After carefully measuring and marking the panel with a grease pencil, I got my trusty Dremel and started cutting...
IMG021.jpg~original
Cutting...
IMG022.jpg~original
The finished product.
IMG023.jpg~original
Another view.
IMG024.jpg~original
And another view.
At this point, it's ready to reassemble. The modified trim panel fits back in place just fine.
IMG016.jpg~original
Yay!
But now, there's the matter of the removable storage cover panel. Unfortunately, the factory speaker panel that is on the JBL-equipped panel is not removable. What to do...? I made my own speaker grill...sort of. Using Adobe Illustrator, I fashioned a template for the speaker grill and printed it on clear acetate.
IMG011-1.jpg~original
I taped it in place and started drilling...
IMG012-1.jpg~original
After drilling all the holes in the panel, I took my Dremel again and smoothed out the surface. I also trimmed down the ribs on the back/inside of the panel, as they were touching the front of the speaker (or at least the outer rim of it).
IMG013.jpg~original
The finished product!
IMG0142.jpg~original
Another view.
In the end, I couldn't be happier. The JL sub sounds fantastic and still retains the factory look. Thanks for all the write-ups here on this board...hope this one helps too!
IMG014.jpg~original
IMG015.jpg~original
IMG020.jpg~original
IMG021.jpg~original
Cutting...
IMG022.jpg~original
IMG023.jpg~original
Another view.
IMG024.jpg~original
And another view.
IMG016.jpg~original
Yay!
IMG013.jpg~original
Another view.
Glad to see you made that all work and look great!! Enjoy it!
I'm looking into doing this with my 08 T4R but I was hesitant because I didn't know where to put the sub. I saw the jl audio stealth box, but it was still in the open so I didn't do it. I LOVE how you did it! It's great! So with that said, where would I get a factory sub enclosure? Where did you get yours?? After seeing this, I'm gonna go for it! Thanks in advance!
I bought the factory enclosure and JL sub from a fellow board member here. Just check the classified section. I think you can also find the enclosure on ebay from time to time as well...
The only update I've done since the install is that I added some sound deadening material to the inside of the removable panel. I took some thin door threshold material (the kind you might put in a doorway in your house to help seal gaps...it's self-adhesive) and added a few strips on the inside where the removable panel makes contact with the interior body panel. I had noticed a little bit of rattle and this seems to have fixed it perfectly.
Did you add the rear speakers?? I have the non-JBL and really want to get rid of the mirrors I don't even look at and add some speakers in the factory spot. Are there threads for doing this?? I haven't found them yet. Thanks
No, I only added the sub. I have replaced all the door speakers with upgrades, and have also replaced the factory tweeters in the front doors with full-range Clarion 3.5" speakers. I've heard of others adding in speakers in place of the rear mirrors, but I'm not sure about any threads dealing with it...
hey catfish looks awesome, this is actually exactly what i want to do to my runner too! any issues with rattling of the cargo door? did you use any sort of sound dampening products? and also do you think the drilled holes play a major part in the sound quality?
Wow. That is very nice. I have plans do do a very similar setup except I am going to build an enclosure in that same location and use the factory bolt locations to secure it. I think drilling out holes to use the panel as a speaker grill is pretty clever. Good job all around.
Not sure how much affect the holes drilled in the panel have on the sound...bass sound waves are large and are non-directional. Well, much less directional than the higher frequency sound waves. But I think having some holes there benefit the sound. I mean, there's a speaker grill on the factory JBL panel, so why not add one to my version?
I haven't had much trouble in the way of rattling either. The only thing I have done to prevent any rattling was to take some thin, adhesive door threshold material (I had some lying around from when I installed a new screen door in the back of my house) and put a few pieces around the inside of the panel where it was making contact with the sub box and/or surrounding areas. That seemed to do the trick.
Thanks for the kind words! Several months in, and I'm super happy with the results!
Where to buy factory sub enclosure
This is a great setup for keeping the factory look. I'm hoping to do the same.
Is there anyone else interested in selling their factory jbl subwoofer enclosure?
