What are you guys doing for adjustable rear control arms (both upper and lower). After adding my 3" lift, I noticed that the WB is a bit shorter and I'm assuming that the pinion angle isn't right either. To correct both, I'll need adjustable uppers and lowers. One option is gathering parts (heims, busings, threaded inserts and tubing) to make what I need, but, being as lazy as I am, I wanted to know what other options (bolt on) are out there.
Thanks!
Jeremy
Thanks!
Jeremy
