advice for body lift install...
Black02
anyone have good tips? Only done one other body lift on a pick up, so that was really easy...
thanks
I recently helped someone from here do theirs. My advice wash all the mud and dirt off the bottom of truck first so it doesn't get in your eyes. Spray a little PB Blaster/ Liquid Wrench etc on the night before so the nuts will come off easily. You will have to pull some trim pieces and lift your carpet to access the bolts from the inside. Don't worry you don't have to pull seats or dismantle entire interior it is really simple and will only take an hour or two. Invite a friend over for pizza and beverage to provide a hand and some support. Use a socket slightly larger then the head of the bolts and a hammer to tap the washer off the facotry bolts as they are pretty stubborn.
Subscribed.
Let me know how it goes and if you run into any snags. Been doing some research on here to do this myself as well.
What size BL are you planning on installing?
Good luck! :D
when doing the steering shaft extension, be sure not to turn the steering wheel. It might seem like a good idea because it's hard to reach one of the bolts, but it messes stuff up if you do turn it.
