Aerosol Sea Foam fouls plugs?
Bretski1
Hey guys, I'm looking to do the spray sea foam that you can spray directly into your TB while the engine is running. I'm wondering if it will foul up the plugs I just put in as it clears the carbon. I threw away my old plugs otherwise I'd put those back in. Thanks.
short answer: It probably wouldn't hurt to change your plugs after doing that.
Sure, you could run the 4runner for awhile, but if it were me, I'd change my plugs and my oil within a week of doing that. (next time, keep the old plugs)
Never used the aerosol but I have used the plain old can of it. I used it twice on my '97 actually, I put a while can through the PCV after I had already changed the plugs and O2 sensor. No issues at all.
When I first bought it, I put 1/2 can through the gas tank, 1/2 in the oil. Changed it about a week later. Not sure how much it did but figuredit was worth a try.
utkrstam
