After Market Sub Install
exclusivebeef
Ok so I know that I need to buy a LOC. When incorporating a LOC into my factory sound system do I tap into the rear door speakers behind the headunit or at the door? Also, where exactly do I connect the remote turn on wire. I have read that it is supposed to be connected to the acc wire, which is where? If at all possible I want to avoid removing my head unit. Thanks
I am assuming you have the non-jbl setup then right?
Well, if that is the case you have two options; really one actually. You can tap into your speaker at the door but better on the passenger side kick pod. But the thing is unless you find an ACC wire elsewhere other than behind the radio that really is your only choice.
IF you have the wiring diagrams you can more than likely find both your rear speaker wires and ACC wires behind the passenger kick pod. Unfortnately I am away from home so I can't pull up the diagrams for the 4r.
