HIR's are your best bet period. Your 4runner needs 9006's in the lows and fogs and 9005's in the hi beam. These are 2X better than the SilverStar ultra's and cheaper now. Read on...
Want to get great illumination without extra heat, wiring upgrades, relays, transformers, and blue tint? Want to SEE better at night instead of HEARING a bunch of dubious chatter about xenon-filled, over-wattage, blue-tinted bling-bling bulbs that are supposedly "just like HIDs"? Want a bulb where you could create a simple swap and maintain the correct filament placement for a perfect light pattern, instead of causing glare and scattered, diffused light?
These Toshiba bulbs are a unique product, the only bulbs available that use the research technology that General Electric patented in 2000 (patent number 6,087,775). It was GE's goal to create a bulb that produced 75% of the light output of HID headlights at 25% of the cost. GE sells HIR bulbs for residential lighting and specialized projectors, but decided to stay out of the automotive market and licensed this technology to a division of Toshiba. In fact, Toshiba and GE are among the few companies in the world with the expertise to engineer and build this product. These bulbs attain light levels 75% to 110% brighter than stock as a result of an engineering process that deposits multiple, yet almost invisible, layers of semi-reflective coating on the surface of a specially shaped quartz bulb. This coating ( a titania/silica, zinc oxide/silica, zirconia/silica, silicon nitride/silica, and titania/magnesium fluoride tantalam/silica multi-layer dielectric, according to the patent) reflects a portion of the infrared energy emitted by the filament back onto the filament, causing it to glow brighter and emit more light from the uncoated forward portion of the bulb. Although the filament gets hotter, the glass does not. IT GENERATES NO MORE HEAT THAN A REGULAR HALOGEN BULB, AND IT DRAWS THE SAME WATTAGE AND AMPERAGE AS THE STOCK BULB IT REPLACES.
These bulbs produce white light with a hint of blue and are rated at 7000k color. They will match 6k and 8k HID kits very nicely.
PM me and I can link you to a place to buy from. IM not sure how vendor rules apply here.
