hulk311
A while ago I installed this horn in my truck. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=94862
While in my brother's basement I found another set of the same horns but the relay is broken. How do I go about installing the set of horns I found to my existing horn without using two relays?
The relay has 4 wires:
-connection to existing horn on steering wheel
-30A fuse
-ground
-compressor
Is is possible to hook up both compressors to the same relay?
Is it as simple as hooking up the 2nd compressor to the same wire as the 1st compressor?
Also, should I increase the fuse?
:awais:
-30A fuse
-ground
-compressor
:awais:
