Aftermarket LED light bars and pod upgrades
assassin
I’m considering putting a solid white light 30 inch single row light bar (spot/fog) in the grille for the faster type runs which require more spot profile beams and Baja squadrons in factory fog location with wide cornering or maybe combo beam pattern for fog/rain. I plan on keeping my headlights and high beams stock still the bulbs burn out.
My question is would this cover my lighting needs well enough? I was considering amber for the light bar but my concern would be the amber might not allow me to have good contrast with sand. I know the white light led bar would be rough with fog because of reflection.
How do amber “spot” beam patterns do in fog/nasty weather?
There’s a big difference in light bars, so the brand you go with will have a lot to do with this. The 30” Baja hi-power combo bar is obscenely bright, not even close to the same class as a 40” amazon bar. If it were me I’d start with the light bar, then use the fog location to fill any gaps.
If you get it all or any part of it through RagoFabrication.com use code T4RZAN for a discount :hat:
I've been considering the RagoFabrication 30" kit w/ the KC lights and I'm very close to pulling the trigger. As bright as bright possible is the objective. How would you compare the KC bar to the 30” Baja hi-power bar?
T4RZAN - I'll definitely use that discount code. thanks for that!
