Aftermarket Rear Bumper Attachment?
BlackWorksInc
So I was trying to find a couple pictures of CBI and some custom rear bumpers and I noticed that they all seem to just bolt onto the bottom of the frame rails where the tow hitch mounts.
That just seems like a lot of stress on the frame rails, am I missing something here?
I'm about to head to bed so I dont have time to look at the pics but from what I am thinking it would depend on mostly the grade of bolts being used to secure the bumper. If they are grade 8 bolts and they are big enough I would think they are pretty tough. I'll look more in depth tomorrow and perhaps I can even send a link to my enginerd buddy at work. He specializes in things like this since we have do lifts up to around 80 tons. I am amazed at what some of the shouldered eyebolts we have will lift.
I'm not sure about the older model of the CBI design but the newer model that I have, has a spacer between the bumper and frame from left to right / bottom to back side, given about 1/4" - 1/2" to flex, it seem to hold up fine, considering all the weight that I have on it.
There are 10 bolt locations:
2 on bottom of frame rail on each side (4 total)
4 on the face of the rear cross member where the hitch mounts
2 below the face mounted rear cross member bolts.
With proper bumper design, seems to be plenty stout to me.
I'm sure someone with the cbi bumper can confirm/deny this but you have 8 bolts secured to the bottom of the frame rails (4 per side), 2 bolts on the bottom of the rear crossmember and 4 bolts on the vertical face of the crossmember right in the center of the bumper.
Most bumper wings directly behind the rear tires have a brace that extends to the outside face of the frame rail that you could potentially weld for added peace of mind.
Edit: relentless beat me to it but the early design of the cbi uses all 8 bolts on the bottom of the frame rails
Confirmed!:)
There are 14 bolts total. 4 on the face of the bumper, 2 on the bottom on either side of the tow hitch, 4 on the bottom of the left frame rail and 4 on the bottom of the right frame rail. Basically the same bolt locations as the OEM weight distribution tow hitch. As Relentless stated, its plenty stout.
P1020093-1.jpg~original
Ah cool, I thought I was missing some other bolt locations. That's good to know! I'll have to start doodling and maybe even do a couple mock-ups on my truck while I scrounge up the money.
