aftermarket water pump kit
88T4RE
hey guys!
I am about to change out the water pump and timing belt on my truck. I found this aftermarket water pump kit super cheap. I'm just curious what you guys think?. I'm not sure of the brand I'm sure it's some cheap Chinese brand although it does say the tensioner is Japanese made? I'm not buying Toyota parts, I'm just not going to spend that much coin. I'm trying to do this on the cheap my engine has 402,000kms and I plan to replace it next year with the 3.4. Also is there anything else I should replace while I'm in there? here is a link to the kit http://mizumoauto.com/product/view/id/559
you're comments are appreciated!
Cheers! :drummer:
Hard to say how good it is, but if I were in your position I would more than likely go for it and hope for the best.
thanks this is no doubt the route I'm going to take as I don't expect the HG to last too much longer on this thing and I don't want to invest too much into it.
Cheers!
Am I correct to think the parts they sell at Napa are the same quality?, they want $90 for the water pump alone.
Napa usually has 2 or 3 different grades of quality per item. You definately get what you pay for at NAPA, the cheap stuff is worthless with the more expensive being a better value per dollar spent.
