Ahhhhh
michael833
So i just replaced the spark plugs/wires and cleaned the throttle body. Now the check engine light is blinking and the whole car shakes like crazy. I want to cry. I am scared. Does anyone know what is going on???????
:smashputer: :cry: :whipping2: :rant: :toilet:
Pull the EFI fuse in the Engine Bay fuse box, look at the underside of the cover it will show where it is. Leave it out for 30 minutes to be safe. Put it back in then get out to the highway and drive it for a bit, and see if that resolves your issue
Well actually after re-reading, are you sure you have all the wires back in the same order?
I couldn't tell you, but if the whole car is shaking its probably something to do with the spark plug wiring order. My friend hooked up every single one of the wires wrong on his heep and the damn thing wouldnt even start. Could be possible that just two are mixed or something
oh okay. how exactly does the numbering go? which plug is number on? etc.
Just search around on google, it took me a couple minutes to find this when i ripped my old wires out and realized i had no idea the firing order. But if you just take a couple seconds to search around you can find the answer. I dont mean to be a cock but its a simple search.
ok ok, i feel bad, let me get you the firing order pic. I was freaking out the day i did this.
It's all in this post.
http://www.toyota-4runner.org/539649-post85.html
thank you! lol I'm usually the same way but I'm freaking out and still have some moving to do. i'mma let the runner chill (literally) then I'll make sure everything is correct.
No problem, i went through that when i ripped te old wires out without knowing the firing order, i researded te firing order before i installed te new wires though, i never had the violent shaking
044runner4
