Air Bubbles in Radiator.
Hey guys,
I just replaced my radiator and filled it with coolant. Started it and waited for it to warm up meanwhile air bubbles kept coming up. After it had warmed up the bubbles kept coming up and never seemed to stop.
Is this normal or is there some problem? Can it cause problems in my radiator or cooling system?
TIA
Hey guys,
TIA
I'd check to make sure ur not possible pulling air in from somewhere (not likely), other then the head-gasket or cracked cylinder head. Rev the engine when ur looking at the bubbles and c if the bubbles increases as u increase the amount of throttle.
Hopefully u just haven't gotten all the air out of the system from replacing the radiator, did u use a coolant vac when u filled?
Check it in few days.. you still have bubbles, you have a leak or head or head gasket issue. Your compression good?
I vote on the blown head gasket too.
It's possible.... could be pulling air from else too.
The quick test if the coolant system is sealed. Is to see if you are pulling and pushing coolant to your overflow tank.
If it doesn't and your radiator cap is good. You have coolant seeps and leaks somewhere.
The best test is a leak down test for this.
I am sure the OP will narrow it down.. :)
The cooling system on these are difficult to purge the air from. Try using a “spill free funnel” and parking facing uphill to get the air bubbles out of the engine. You’ll also want to turn your heat and rear heat (if equipped) on as well.
This is the spill free funnel that I use: Lisle 24780 Spill Free Funnel with Standard/GM/VW/Ford Adapters https://a.co/d/hwSliuB
EDIT and slight rant: Why are people assuming it’s the head gasket? Isn’t it much more likely that there’s air pockets in the cooling system from having to drain the system to replace the radiator?
Where has diagnostic reasoning gone? Ever since I did “X” then “Y” has happened. THAT’S BECAUSE “X” CAUSED “Y”!!! “Ever since I pulled this fuse my radio stopped working, could it be the battery?” NO!!! IT’S THE MISSING FUSE!!! “Ever since I replaced my valve cover gaskets I got a P0171 lean code, could it be my injectors or my air/fuel sensor?” NO, AGAIN! IT’S THE VACUUM LEAK YOU CAUSED BECAUSE YOU DIDN’T PUT THAT VACUUM HOSE ON OR DIDN’T PUT THAT INTAKE GASKET BACK! See where I’m going with this?…
With no loose coolant hoses and a good radiator cap your cooling system should purge the air out in around three drive cycles.
Keep topping off your expansion tank.
Everyone was really helpful.
I don’t think I have a blow HG. There would be more symptoms with that and I haven’t experienced none.
I believe the air simply hasn’t been expelled out completely. I say this because I had been driving it with a leaking radiator (hole in rad) for about two weeks. I just kept topping it off and never really waited for the air to be released. My transmission fluid is as good as can be (no milkshake). And my engine oil is pure also (no sludge whatsoever).
When I drained it I only collected about 1/2 gallon of coolant.
Because people didn't diagnose the problem. I think it's a good rant myself [MENTION=8262]badluck[/MENTION]. Folks don't want to take the time check and verify. I agree it takes a while to get all the air out of these coolant system. :)
Filling the motor with coolant using the upper radiator hose, before connecting it to the radiator and filling it up all the way seems to reduce the air pockets.
I also had better outcomes filling the cooling system through the upper rad hose going into the motor. And I bleed going through one heat cycle with the spill free funnel Bad Luck mentioned.
Between all that and monitoring the overflow catch container after a going through a couple of heat cycles does a really good job in bleeding the cooling system.
I believe the air simply hasn’t been expelled out completely. I say this because I had been driving it with a leaking radiator (hole in rad) for about two weeks. I just kept topping it off and never really waited for the air to be released....
Best place I've found to let the cooling system air out is at the point of the heater control valve, the highest point in the entire cooling system. Don't forget to turn the rear heater on for full bubble removal. Luck.
Bad Luck;3785381 EDIT and slight rant: Why are people assuming it’s the head gasket? Isn’t it much more likely that there’s air pockets in the cooling system from having to drain the system to replace the radiator? Where has diagnostic reasoning gone? Ever since I did “X” then “Y” has happened. THAT’S BECAUSE “X” CAUSED “Y”!!! “Ever since I pulled this fuse my radio stopped working said:
That's not a rant that is in fact trouble shooting 101.
Just seems like we get a lot of people asking for help around here, and it's usually caused by whatever they just did. I don't mind helping to troubleshoot/diagnose but at least check over the work you just did and verify that it's not the cause.
I just hope in time they learn this. Granted, if they instantly just start throwing parts at things over and over again.
I am kinda thinking they are not learning proper troubleshooting. As I know for me, I don't like doing the same job over and over again as I have better things to do. :)
How is this project coming along? Are the bubbles working themselves out? Update available?
AndiGarage
