Air Shock Tech
Yota Buck
Monroe MAX-Air Shock part # MA700 works for the rear of 1995 4Runners. They are a little longer than the stock shocks for the rear. I raised the rear about 2" . The ride is much "firmer" too.
I already installed the Moog coils but wanted a little more lift and support when towing. Now my 4Runner sits a tad bit higher in the back. Looks a lot better.
Stock rear shock specs- (referenced Monroe Reflex shocks)
13.25" comp. 20.875" ext. 7.62" trav.
Upper mount- S4 Lower Mount- L3
Monroe Max-Air specs- 12.75" comp. 21.375 ext. 8.62" trav.
Upper mount- S4 Lower mount- L1/CP3
You will see that the "lower mounts" have different codes. Don't worry. They will slide up on the mounting "pins" with a little grease and a small C-clamp. Use your factory bolt to retain it.
I also used 2 extra washers to space them out a little on the backside.
I am running 70 psi right now.
I'll try to upload some pics to my homepage...
Hope this helps someone with the "sag"
Peace,
Yota Buck
Peace,
Yota Buck
You still like this set up?
I was going to do the same
Wow ! Blast from the past. I ran this set-up till I sold my 4Runner last summer.
Never had a problem with it. Would advise it to you as a good set-up.
Go for it dude.
Peace,
Yota Buck
