Airing Down While Off-roading and a Neat Trick
Thai
Elite Member
Here is a post by a very knowledgeable (IMHO) guy on the G forum: (neat trick is at the end of this post)
"When driving off road, pressures should nearly ALWAYS be lower than when driving on road. Always is a big word, I know, and I'm sure people can come up an exception or three. But the point is that you'll always be easier on the terrain when you spread your footprint out. Heck, I could make a good argument that people should lower their air pressure when they turn from the pavement onto the dirt road I live on. I bet we'd have a lot less trouble with the road turning to washboard. The point is yes, make it easy to air down and back up so that you aren't just doing it after you've lost traction or suspect you might. Lower is better just about all the time off road.
Staun deflators or a similar system is wonderful for regular lowering of pressures. I don't set them to the last PSI before the tires peel off the rims, but set them to get from 35 down to 20 or 22 psi quickly and easily so I can do the airing down that will help take it easy on the ground and get through 99% of what the vehicle can do. If some unusual challenge like shallow mud I might need to cut through (need more pressure) or super soft sand (need less pressure) comes up, it can still be dealt with at the time.
Being set up to generally air down before getting on the trail and back up after getting off (and using the systems regularly) is no different than having proper tires, tools, etc. It's part of being properly prepared for off road travel, I think.
It doesn't have to be expensive. The Staun deflators are pretty cheap and save a lot of time when lowering pressures. Even a cheap compressor will get you aired back up. It'll take a little time, but as long as you pack a cold beverage or snack to enjoy while it's going on, this is a great time to stop with buddies and talk about how much fun we had before we part ways. Heck, the slow compressor might be better in that respect. It gives time to talk while you leave the inflation system unattended to fill the tires.
Here's a good trick.
Use a 4-way splitter hose to hook up all the tires at once. Right at the place where the compressor hooks to the splitter hose, put a T in the line with an extra schraeder valve. Some compressors already have the extra schraeder valve for checking pressure. Buy an extra Staun Deflator and set it for your road pressure and screw it onto the extra schraeder valve. Hook up the compressor, turn it on and let it run. Go have a sandwich and a beverage with your buddies. When you hear that Staun deflator pop off, it means your tires are back up to road pressure. Unhook the compressor and go!
All the best,
-Dave G."
Staun's Cheap...? They cost more than my compressor. Even off-roading once a month, I will use the back of my $1.00 tire gauge.
Re: Re: Airing Down While Off-roading and a Neat Trick
Yeah, but you cannot beat the speed of deflation. I can deflate all 4 of my tires to a preset psi quickly and all at the same time. Your $1 tire compressor cannot come close. Once you have use them, you will wonder why you did not buy them sooner! :) Or you can use 2 of the Staun and give the other two to your friend...so, both of you can deflate quicker than the traditional way (via $1 tire gauge).
IMHO, Staun deflators (or whatever other brand you buy) are a "must-have" for the off-roader.
ric said:
Im missing something here, is there a photo somewhere ?
Is it something like this : http://www.4crawler.com/4x4/ForSale/4air.shtml
I don't know, but the idea sounds pretty good. I just need to sit back and think it through...i am happy with the speed of air up with my Pep Boys air compressor that i am not sure if i want to go through with that project. (With two very young kids at home, i don't seem to have much time with "other" projects.)
Re: Re: Re: Airing Down While Off-roading and a Neat Trick
Maybe if I could find four people in my area who need staun's I could justify the cost. :D
I'm gonna have to agree with Thai....
I bought a set, and now after using them I don't know why I didn't buy these sooner, so easy to use and pretty cool, all my friends always want to borrow mine when were deflating....
I REALLY like that trick in the end of that post. I have thought about getting a hookup for 4 hoses so I can do all at once, but I never thought about having a Staun on there to prevent it from airing up too much. Very smart!
Re: Re: Re: Re: Airing Down While Off-roading and a Neat Trick
start charging them a buck every time :bigok:
Get yourself a clamp-on air chuck :
add a Q-D (like 2nd from left) :
and for about $3 total you can air down easily, and an air gauge slips right on the Q-D fitting to check the pressure.
I carry 2 so I can do a side at a time, takes about a minute to take my 36's down from 30psi to 15, then I keep watch as take'em down to 12.
ric said:
those look just like the Stauns, so you would only save $10 over the Stauns, not much recovery gear there, lol
You might be right, but at least at 4WheelParts the smitty's are $40. The Staun's are $60. That's good for at least one clevis shackle. :biggrin2:
look around online, I got my Stauns for $50 shipped to my door.. but yea $20 is $20 :bigok:
Here's a cost saver!
We've all bought several can of tire inflator stuff over the years with the small hose Schrader adaptor on the end. The cheep ones only cost a couple of bucks.
Gather up 4 of them, cut the adaptor off the end and use that as your tire deflator. Best if all 4 are the same.
Install them one at a time walking all the way around the vehicle. Check your watch and after a predetermined wait, make the 2nd walk around removing them. Finish up using your tire gauge. I find it's very easy to get well within +/- 3 psi of the desired pressure once you
would this work?
hi everyone; I really like the idea at first post in this thread to create hoses from a splitter for airing up with one Staun deflator to release when it hits road pressure. All four tires will balance to that same pressure. I'm going to install a compressor over the right wheel well, and make up the hoses this weekend.
Gives me another idea. Why not use that same web of hoses with a second Staun to deflate. All four tires should balance to the offroad pressure, shouldn't they? Then get together with a buddy, buy one set of Staun's between us, save some bucks, and have a convenient system.
Any thoughts, would one Staun work for deflation just like the OP suggested for inflation?
