Ajohnson85's '87 build
So cool! Nice work!
Thanks bud. I'll have it swapped this week. Then I need to work on mounting my new piece of camping gear.
Indel B 50 qt fridge with slide. Got it from the group buy. I'm gonna make my own mounting plates and wire each truck so I can use the fridge in either one.
I pulled two leafs out of the front and rear of my trail gear leafs. Rides like a slinky but way better than bouncing around like a hoopty. I'd also replace the center pins with some allen head bolts. Makes it faster to replace the broken trail gear parts in the future.
The springs are fine for me. I just need to replace the center pins. I didn't even realize they were broken :confused:. 22re balls to the wall
Pretty common to have more leafs for a more progressive spring rate. It's only 6 main leafs, the top and bottom control axle wrap. These are All Pro springs I have on my Tacoma
Waiting on a replacement rear brake line, so I wired a 12v outlet for my fridge, it also has a USB port, and finally got a tote so I can organize my recovery gear.
3' tree strap, 10' tree strap, 30'x2" strap, 30'x3" strap, 20'x7/8" kinetic rope, smittybilt snatch block and tire plug kit, and D ring shackles.
Still need to mount the slide, I'm gonna bolt some plates to the floor with nuts welded on so I can easily remove/install it.
seltzernator
