Ajohnson85's '87 build
Here is an idea of how the sticks will look when finished. I bent the outside sticks inward, but I'll still need to trim the bezel if I don't cut and rework the sticks around it. I'll make a new red leather boot to finish it.
I reinstalled the gas tank, welded the diff guard to the rear axle and painted it
And messed with my artec 31m battery box. I removed the plastic intake sheild behind the headlight. I might look at relocating the coolant reservoir to behind the windshield cleaner reservoir, but I could make it fit like this with some 1" spacers underneath the box.
The fitting of the shifters is awesome, well done!
Thanks bud!
I'm prepping the stock steering pump to run hydro assist. I removed the restrictor plate to drill it out to 13/64". This will give more flow and hopefully let the ram and box work without any lag.
Any updates on the hydro assist? do you know what PS reservoir you will be using? I dont think ill be able to use the reservoir that i got with my high steer so im looking for new ideas.
I haven't had any time to work on it. I decided to order a TG pump kit. Originally I was going to cut and weld 2 stock reservoirs together. I think TG sells a larger reservoir by itself.
I took my rear axle housing to a buddy's house lastnight, he torched the spring perches off for me. The rear shackle hangers are in a good location and the springs are hung. Both axles are torn apart. The weather will clear up later this week, hopefully I can make progress and get the axles hung soon.
Ive seen the TG ones and also though about making a smaller stock extended reservoir, but then i came across this Custom High Mount Reservoir looks like it would be a lot easier to get a higher mount without sacrificing capacity.
DionicioLives
